Make only connectable iMates visible with Alt drag.
When i select an insert iMate and drag it all insert iMates become visible. The down side is that only the ones with the same Offset and Solution (Oppossed or Alligned) will actulaty connect.
Same goes for all iMate types.
It would be great if only the iMates that can actulay can connect will be visible during the alt-drag.
2 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
