Loads in User parameters
Is it possible to set loads used in Design Assistant as User Parameter? In this case parameter from gear calculation could be exported. Then this value can be used in shaft calculation, then loads on shaft supports will be placed in User Parameters and exported and after all, loads on shaft could be used in bearing calculation.
