Link excel parameters file in IDW
You can link a excel file in a part and assembly file, but this is (surprisingly) not possible in a idw file. Please add this!
When I need to make a dozen of drawings for a certain assembly where only a few dimensions change, I want to use illogic to update the drawing linked on parameters from excel.
This works perfect on assembly level when linking the excel with an assembly, but surprisingly you cant do this on drawing level as you cant link an excel in a idw….
3 Comments
Seems there is a little bit of a work-around (although this does not fix it for me):
Manage -> insert -> Existing file -> excel (link)
And once you have that turn vivibility off for the table thats created...
BUT! now it still can not be used within the ilogic as it can in a assembly or part....
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
