Level of deatail - Relashionship between parts and positions
LOD = Level of Detail
Connecting parts using LOD task, the parts could assume different positions and/or suppressing parts as per you request the LOD. You link what you need and all changes are done only swaping the LODs. Ex:
Assembling with A B C parts
LOD 1 = A mating parallel B with 20mm far from each. C suppressed
LOD 2 = A mating parallel C with 30mm far from each. B suppressed
LOD 3 = C mating concentrical B with  10mm far from each. A suppressed
Resume: You put all parts you need in an assembly, raise all constraints, raise the LODs, only turn it on/off parts and constrains per LOD created, and it changes automaticallyLOD Issue.jpg
8 Comments
DRoam
Fortunately, I think the functionality you're needing already exists as iAssemblies. You can specify suppression of parts as well as constraint values.
1st of all thanks for the reply.
I'll try the iAssembly but, the idea is to get faster.
Doing this (avoiding the command) it'll be faster.
You do the configuration that you want only using the left tree.
You rotate the model or assembly and change settings directly on the left tree.
Imagine having to open the command all time I need to change any parameter.
This happened in a 4 parts assembly. And if it were in a 30parts assy?
In a 30parts assy, you could go easily thru the left tree and change it because you got the name and also the colored figure.
Much more easy (taskly and visualy).
Resuming:
1 - You create the Level Of Detail (A)
2 - Create the mates
3 - Create the new LODetail (B)
4 - Suppress all mates (A) you use to have
5 - Create new mates
6 - Go to LOD (A) and suppress all (B) mates.
OBS: Same with the parts
Done... all on the tree
Tanx
Saulo Ribeiro
This message may contain confidential information which may also be legally privileged and is intended only for the use of the parties to whom it is addressed. If you are not an intended recipient you are hereby notified that any disclosure, copying, distribution or use of any information in this e-mail is strictly prohibited. If you receive this message in error please notify the sender by return e-mail and then destroy it. Further, we make every endeavour to keep our network free from viruses. However, you do need to verify that this e-mail and any attachments are free of viruses as we can take no responsibility for any computer viruses which might be transferred by way of this e-mail. All information and attachments remain the property of Subsea 7 and should be held as confidential.
DRoam
I don't think the workflow you're proposing is any faster or easier than an iAssembly.
Once you convert your assembly to an iAssembly, if you change to "Edit Member" mode, any changes you make as far as suppression (actually it's called "exclude" for an iAssembly) or creating/editing of mates will only be saved to that member.
In fact, this is even better than linking constraints with LODs because with iAssemblies, you have the iAssembly table which you can edit within Excel and bulk-edit several members as necessary. The iAssembly tool is very powerful, I'd suggest you look into it.
If you wish, you could post a question in the general forum for some help in how to get iAssemblies to accomplish you needs: Inventor General Discussion
Hey, good morning and thank you back again.
I've done the iAssembly with success and it had respected the mates as per I changed the configuration.
The construction is as per you told me. There's no big mystery to do that but, can be more simple.
The way I've explained, I've already used once. And it was faster. Believe.
Other thing is, I also could create a table from the left tree after the configs done.
But anyway. It's just an improvement that I think that it'll be decrease worktime.
Again, thank you so much for the reply. It worked.
And also thanks Autodesk for the space. It's really helpfull
Cheers.
Saulo Ribeiro
DRoam
Not a problem, glad the iAssembly will work for you. Just out of curiosity, which software package has the functionality you're talking about? Solidworks?
Hey. Good morning.
Yes it is.
TopSolid also does this task
Saulo Ribeiro
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
