Inventor Dynamic Simulation Input Grapher Polynominal Motion
The Dynamic Simulation input grapher currently allows the input of coefficients for a polynomial equation (for instance 6 coefficients can be entered for a 5th order polynomial). While this is mathematically sufficient, the best way to define the curve from a design point of view would be to enter the position (mm), velocity (mm per s) and acceleration (mm per s^2) for the start point and the end points of the curve.
From a functional point of view this would then allow the user to match the adjacent segment  position, velocities and accelerations to avoid shock/impulse loading at the start or end of a cam ramp for instance. This would enhance the usability of Dynamic Simulation. This functionality is typically available in other motion design packages.
3 Comments
Sorry for the typo in the title .. should be Polynomial.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
