A concern regarding STEP/STP to Inventor IPT conversion and Pack & Go is being raised, along with a request for guidance and possible improvement.
1. STEP to IPT conversion
The expectation is that when a STEP/STP file is converted to an Inventor IPT using a non-associative conversion workflow, the resulting IPT should be completely independent of the original STEP file.
For example:
Supplier_Model.stp → Convert → Supplier_Model.ipt → Save
After this conversion, the IPT would be expected to work independently without Inventor later asking for the original STP file when the IPT is moved, copied, or included in Pack & Go.
However, there are situations where Inventor subsequently asks for the original STP location. From a user's perspective, this is confusing because the IPT appears to be a native, independent Inventor file.
Could the Inventor team please confirm whether this is expected behavior and, if so, explain what reference or dependency is being maintained?
2. Pack & Go and independent copies
A related concern is the difference between packaging a design and creating a completely independent copy.
The desired workflow is simply:
Original Assembly → Create Independent Copy → New Independent Assembly
The new assembly should contain independent copies of its editable subassemblies and parts. Any changes made to the new assembly or its copied components should not affect the original assembly or its original editable components.
For example, if the original assembly contains:
Original Assembly
Subassembly A
Part 1
Part 2
Part 3
the independent copy should contain:
New Assembly
Subassembly A (Copy)
Part 1 (Copy)
Part 2 (Copy)
Part 3 (Copy)
All internal references should automatically point to the copied files rather than the original files.
It is understood that Pack & Go is primarily intended for packaging and sharing, and that iLogic Design Copy, Design Assistant, or Vault may be more appropriate for some copy workflows.
However, a simple and reliable "Create Independent Copy" or "Make Independent" option would make this workflow much clearer and safer.
3. Request for guidance
Could the Inventor team please advise:
What is the recommended workflow today for creating a completely independent IPT from a STEP file?
What is the recommended workflow for creating a completely independent copy of an assembly?
Is there a way to verify that no hidden external references remain?
Could a future version of Inventor consider a dedicated "Make Independent" or "Create Independent Copy" workflow?
The main requirement is simple:
Once an independent copy is created, there should be confidence that editing or moving the copy cannot modify or unexpectedly depend on the original design or its original STEP source.
Thank you for your time and for any guidance you can provide.
