Improved Transparency of Reference Geometry for Component Patterns in Assemblies
Hello Autodesk Community,
it would be very helpful if, in Autodesk Inventor, it were possible to clearly identify which work geometry (axis or plane) a component pattern in an assembly is based on.
Currently, while it is possible to create a component pattern based on an axis or a plane, the reference geometry is often nested within a part that is placed in the assembly. As a result, it is not clearly visible within the assembly itself which specific work axis or work plane the component pattern refers to.
At the moment, it is not clearly identifiable
  • which work geometry (axis or plane) a component pattern is based on.
In parts, this behavior is already very well implemented: it is clearly visible which work geometry a pattern is based on. A comparable level of transparency would be highly desirable in assemblies as well.
Suggestion:
Provide a clear display of the reference work geometry (axis/plane) in the properties or in the browser of the component pattern, ideally with direct highlighting or a link to the referenced geometry.
This would significantly improve traceability, maintenance, and troubleshooting in complex assemblies.
Thank you very much and best regards,
Alexander
https://forums.autodesk.com/t5/inventor-forum/identifying-reference-geometry-for-component-patterns-...
