Hi Guys,
I've got an STL file which come from laser scanning and I've tried to create the analytic model using the Fit Mesh Face command, but as I see currently there is no chance to do it. I've found many limitation of this command during I trying it:
1. Possibility to switch off the preview
Now the software restarts the calculation after every changes and this is very time consuming with complex data
2. Possibility to terminate the process by ESC
Now in many cases just waiting, just waiting, just waiting, and then kill the process by Windows task manager 😞
3. Improved fitting algorithm
Now the software fails to fit the face in many cases escpecially the spline faces. Spline method also can't handle closed face.
And some more:
5. Tools for mesh editing, like Meshmixer. There is another idea about this: https://forums.autodesk.com/t5/inventor-ideas/integrate-meshmixer-make-the-meshes-a-1st-class-citize...
6. Possibility to unselect the selected elements
7. More selection methods. For example by window, or automatic selection by tolerance, etc.
8. Option to select or not select the invisible mesh elements
9. Possibility to switch off automatic curve fitting during projection to sketch
Attila Farkas
