when importing .jt files it is not possible to set up a folder structure. So every sub-assembly, every component etc. will be all saved in the same folder.
For small Imports there is a workaround but the bigger the assembly gets, the bigger gets the work for cleaning up the folder.
Not every single component that is in the main assembly has to get an invidividual file path. But if the sub-assemblies and their components could get one this will save a lot of time.
Like in the picture above so that i can select a file path for the sub-assemblies.
