I posted in the iLogic forums about the inconsistencies between the iLogic Event triggers that are available in the "This Document" tab when working on a part, and the global "Part" tab.
The main issue is that the "Part Geometry change" trigger isn't available globally for part files. "iProperty Change" is also missing from the "Part" tab.
I'd like to see all triggers made more consistent so that everything that is available under "This Document" for parts, assemblies and drawings are also available under their respective tabs.
Parts aren't the only filetype affected. There are 9 triggers when working in an assembly under the "This Document" tab. There are only 6 available under the "Assembly" tab.
Original discussion is here:
https://forums.autodesk.com/t5/inventor-customization/part-geometry-change-event-trigger-not-availab...
