Having layers inside sketch environment
To be able to use layers inside Inventor sketch, to turn the visibility of different outlines on and off.
It is a time-save to have more complete sketch instead of creating multiple simple sketches, as you have to place your references over inside each new sketch. If you attempt to have a too complex sketch now, picking profiles becomes retarded, rendering that sketch useless.
This issue becomes particularly apparent when working on multi-solid bodies.
Anybody else noticed this?
rob
3 Comments
DRoam
@robert_szykowski, even though your Idea is the original, there's a duplicate which has received a little more support at this point in time (15 votes at the moment). As such, I'd recommend casting a vote for that Idea as well. You can do so here:  Sketch layers
I like the comments you made, though. I think they're great points. It definitely does save time to have a single complete sketch rather than several small sketches with lots of projected geometry. But, like you said, having a complex sketch now can make profile selection a real pain as Inventor starts to not recognize profiles even when they truly are closed. Being able to assign certain closed profiles to a layer would be a perfect remedy for this.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
