Hi, does anyone know if it is possible within Inventor to automatically set the angle of hatch lines to i.e. 45 & 135 degrees?
As when I section a 2D drawing, especially an assembly the angle of the hatch lines seems to be randomly generated to an angle with several decimal places, which doesn't look professional on the drawings.
I would have thought this would have been a parameter you could set within 'Styles', but cannot find anything.
The only solution I've come across is to select each individual section area an then adjust the angle, which is time consuming and frustrating.
Maybe this is something Autodesk should include in one of their many updates.
Any advise, thoughts or solutions on this are welcome.
