Flat pattern Orientation option
I would like to have the option to set the flat pattern, to be true the X,Y,Z axis. I want this to be a setting in the sheetmetal template or in the Inventor options. At the present Inventor "optimizes" the flat patterns from time to time. We use iLogic to extract the Sheet Metal Extents, and this is done automaticly, but gives some strange results due to the rotation. I know I can set this straight after the flat pattern is created, but that's just what I want to avoid. I beleive a simple setting like this could make life  so much easier.
2 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
