Dear Autodesk Inventor Development Team,
I would like to suggest a new feature enhancement for Autodesk Inventor that would significantly improve modeling flexibility: the ability to redefine the part origin and XYZ axes—not just the visual orientation, but the actual coordinate system used by the part.
Currently, users can adjust the ViewCube or set a new Front/Top view, but the internal coordinate system (used by work planes, sketches, constraints, and export references) remains fixed based on the original base features. This can be problematic when:
A part needs to be reoriented to match a different assembly or coordinate system standard.
A model was created in an unintended orientation and requires correction.
The current coordinate system does not align with downstream manufacturing or simulation requirements.
Proposed Functionality:
A tool to redefine the part origin and reassign the X, Y, and Z axes direction.
Optional update of dependent features, sketches, and constraints to follow the new coordinate system.
A user-friendly interface with preview and rollback options.
Why this matters:
Changing only the view does not help when exporting files, using model-based definition (MBD), or integrating with CAM/CAE tools. A true coordinate system redefinition would offer users much more control and save time that is otherwise spent on rebuilding geometry or using cumbersome workarounds (like reimporting parts or using derived components).
Thank you for considering this suggestion. I believe this feature would be a valuable addition for engineers working with complex assemblies, imported data, and multi-software environments.
Sincerely,
Ahreum Park
