Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
FEA REPORT, SAFETY FACTOR. SHOW IN MODEL
Inside the analysis environment after running a simulation the 5x results bars are displayed in colours from blue to red.
Within the Safety Factor results bar there's also a marker for the minimum value. It should be possible to click on this minimum  value and then press 'show in model' which should zoom in to that specific area. This way you know the correct spot which is currently the weakest link and needs attention.
