Extrusion Dimension Select
Starting with the hole feature in 2019, this new pane modelling feature does not allow for users to click on a visible sketch dimension.  This was a nuisance with the hole feature because most are through all, but now effecting extrusions this problem is magnified.  Please allow us to select visible dimensions when we have the distance A box highlighted.  It is a huge boon to modelling robustness if dimensions are easier to reference when creating features.
2 Comments
DRoam
Hi @Anonymous, if you hold down the Ctrl key you can click visible dimensions as you're wanting. Agreed that the old way was better. Hopefully this will be improved in future releases.
jason_hetu
We are working on a change to this behavior that would be single click to refrence and double-click to edit that dimension. Hopefully this will solve the issue for you, but in the interim try Ctrl+Click as suggested above.
