Expose Tube & / and Pipe Style for a Route
All,
I would like to be able to access the style for a given route in Tube & Pipe for some programming purposes.  Currently it doesn't look like much of the API for Tube & Pipe is available, so I'd like that to happen or for the Active style of a Route to be exposed as a property (custom iProperty, even) that could be read and utilized to populate downstream operations, such as adding fasteners to flanged pipe connections.  Hopefully this makes sense, but please let me know and I can try to elaborate in the comments below.  Thanks for your consideration and have a most blessed day!
Peace,
Pete
1 Comment
A.Acheson
To workaround  the lack of access to styles API here is a forum post link to change route styles in and assembly. Hopefully you can modify as needed.
Here is a rule to get the full list of styles thanks to @Tom_Fuller and to get the active style in a route.
	Dim oDoc As Document = ThisDoc.Document
	Dim oCDs As ControlDefinitions = ThisApplication.CommandManager.ControlDefinitions
	'Active Style (Combo Box Tube and Pipe Styles).
	Dim oCD As ControlDefinition = oCDs("HSL:Piping:StylesComboBox")
	'Cast to ComboBoxDefinition.
	Dim oComboBoxDef As ComboBoxDefinition = DirectCast(oCD, ComboBoxDefinition)
	'Create a New List.
	Dim StyleList As New List(Of String)
	For i = 1 To oComboBoxDef.ListCount
		StyleList.Add(oComboBoxDef.ListItem(i))
	Next
	Dim StyleName As String  = InputListBox("Prompt", StyleList, d0, Title := "Title", ListName := "List")
	MessageBox.Show(oComboBoxDef.ToolTipText, "Active style when in the Route")
