export to protected PDFs and watermark
Just a couple of small ideas.
It would be nice if the export/save to PDF function had a few options.
Currently the Save as PDF option saves several layers into the PDF that can be turned off independantly and printed.
If we give a drawing out this means that someone can turn our border off and give the document out as their own drawing. It has happened.
One solution we came up with was to install CutePDF writter. It comes up as a printer and doesn't produce any layers in the PDF file, making it harder to steal the information. It would be nice if Inventor could do this without having to install some third party software.
When we looked into protecting our PDF files we also considered watermarking. We came up with a solution, but I find it annoying when Inventor does not already provide this feature. The student version already contains a watermark so would it be such a big leap to give us access to add our own watermarks?
Regards
Kenny
3 Comments
Similarly, being able to add a watermark to 3D PDFs as well.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
