This tool combines several steps of the usual construction of such elements, allowing you to immediately control almost all the parameters listed in the dialog box.
Several suggestions that would improve the tool:
- position snapping - not only to the center of the groove (sometimes it would be necessary to snap to the center/s of the fillets - now it is impossible to change this even through its sketch, where there is only a center point);
- provide the possibility of creating the same element along an arc (as in the "Slot" command in the sketch).
