When creating detail drawings for parts within an assembly, I often have similar parts that differ only slightly in length. Is there an easier way to use the “Replace View Reference” functionality?
When the parts share the same geometry but have different lengths, I can copy the existing views and replace the model reference. This does a great job of retaining most of the dimensions, view scales, and formatting.
However, the current process is a bit cumbersome. I have to open a separate drawing, paste the views into it, replace the model reference under the Manage tab, and then copy the updated views back into the original drawing.
Is there a more streamlined way to accomplish this directly within the original drawing? Ideally, I would like to replace the model reference for the copied views without having to move them to a separate drawing and back.
