Drawing dimension with an unassociated end
Would like the ability to created a dimension with an unassociated end(s).  This dimension could stay the pink color or be a completely different color with a different command.  We do a lot of these types of dimensions to show pallet lift offs for the fork truck drivers, show where the shop would need to grind welds to allow for clips to attach to reinforced frames, etc.
3 Comments
jletcher
UGH draw a sketch in the view put a small line finish the sketch and dimension.
 Or put the sketch in the model then in IDW Get Sketch and dimension to it..
 No need for this at all...
 This is not the norm.......................
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
