Dimension: Place tolerance after a hidden dimension value
On an drawing .idw, we often need to hide the dimension value and replace it by text. It's impossible to add some tolerance (Deviation tolerance for example).
Please improve Inventor to add the tolerance after a hidden dimension value.
3 Comments
gabriel_deber
Override the value doesn't work for you?
If you overide the value instead of hiding it you can use all available formats for dimensions.
jvidecky
Gdeber: Are you tested? ... I think no. .... Because, your advice is for numerical value. No text value.
filippo.toniello
It will be very useful for iassembly or ipart familty drawing tables without pokeing with text notes
but this should be very useful instead
stacked text
