Design Accelerator - "By Hole" Option
I'd like to see an option for the "By Hole" placement method incorporated into all DA functions that support "By Hole" placement.
When I use "By Hole" placement and select an existing part hole feature, the existing part containing the referenced hole feature is not updated/modified as the connecting object diameter is changed
The logic of this current method is sound and I don't argue its validity (i.e. post assembly matching/reaming operations).
(Another suggestion I suppose... Have an option for the connection to automatically create an assembly feature to represent this)
However, there are times when I would like the existing part hole feature to update when a connecting component diameter changes to be either larger or smaller.
This optional function would edit the hole feature(s) in the impacted part file(s) themselves, enabling the ability of the part feature to be re-sized smaller or larger based upon the connecting part.
This option should function regardless of how the connection change in size is accomplished; both changes made manually by the user, or as a result of using one of the design calculation methods provided on the "Calculation" tab.
Best,
Brian
2 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
