Data from spring in to BOM
Saving data from spring in to the file so that it can be found in the bom.
For example, that it comes in the stock number.
Useful information here seems to me to be foor example:
- Wire diameter;
- Spring diameter;
- Loose spring length;
- Max Load;
- etc.
2 Comments
RajSchmidt
You can mark the required parameters as “Export” (in the parameter table). Then they become available as User Defined iProperties and can be used in the BOM.
geert.van.pelt
Yes I know, however not all data is returned in the parameter table.
See the images below for additional information.
Spring Design Accelerator (1).pngSpring Design Accelerator (2).pngSpring Parameters.png
