Custom Border with fixed zones sizes
Inventor contains a border with zones by default. The zones of this border have a fixed size. When the size of the sheet changes the amount of zones is changed accordenly. I like to enlarge the left space only of the border to follow the ISO standard. It is not possible to change the sketch of this default border.
When I create a custom border with zones I can define the width of every side, which is exactly what I missed in the default version. But the zones I defined (named A, B, C and 1,2,3) do not keep the fix size. When change the sheet size from A4 to A0 the zones are much bigger.
I wish to be able to change the default border definiton like the custom border but keep the correct behavior of correcting the amount of zones when the sheet size is changed.
iLogic is a (weak) solution:
1) The rule must be triggered when the sheet size is changed. (Is this possible?)
2) iLogic code is open for editing and can be damaged by users.
.net custom made app:
1) Technical possible but needs to be updated every time when upgrading to the next Inventor release.
2) Not supported by Autodesk when issues pop up.
Both routes are not my choices, this behavior must fixed in the standard software.
All comparable CAD systems can do this, why not Inventor?
3 Comments
Frodl
I miss this possibility also.
david.wartaJA24W
This would indeed be very helpful. Hopefully it will get the attention it needs and will someday get the status implemented.
D.Warta
Van Halteren Technologies Boxtel B.V.
Torsten.Hoeflich
From our point of view, it would also make sense to automatically adjust the zones depending on the sheet size (e.g. A0 ... A4). Two setting options would be good.
1. a kind of list values, e.g. for A0 - 24 horizontal, 16 vertical. The number can be defined for each sheet format.
2. a fixed zone width in horizontal and vertical direction, e.g. horizontal = 50 mm, vertical = 40 mm. If the sheet size changes, more/less zones are displayed accordingly.
