Idea:
Add the ability to apply a weld prep (chamfer) to a part file from within the Weldment (assembly) environment or in Frame Generator instead of it being at the assembly level.
Reason:
At the moment, it is only possible to create a weld prep feature at the assembly level in a weldment or frame generator.
In an assembly company it is sometimes more efficient to have the sub-supplier add the weld preps to a part before delivery so that the welder doesn't need to prep the parts.
This means adding the preps to the part drawing - rather than on a welded assembly drawing, which means the chamfer needs to be in the part document instead of the assembly.
This is also better when re-using parts, as the prep is applied to all parts with one instruction and only needs fixing in one place if it goes wrong when making changes.
Currently, this is achieved by opening the part file and making the change there, potentially losing the prep when a frame is altered and having to add it back in.
It would be better and faster if this could be an "assembly driven" feature in the weldment or frame generator environment, that applied to the part file when working with the frame generator or with weldments.
Option 1:
In a Weldment, click Preparation, then apply a Chamfer feature.
or
In a frame generator session, click a new Chamfer option:
Select the "Apply to Part File" option to make this a part-level feature, rather than an assembly level feature.
