Create coincident constraint "on center" upon Section View creation in IDW
I'm not sure how many of you run into this, but here goes my idea....
We deal with pressure vessels so naturally our products are round. When you create a section view the sketch is projected so it knows if there is a center or not. As you all know, it will create either a vertical or horizontal constraint automatically when you create a Section view based off something round in the corresponding view. The issue is the section line is not symmetric on the part, or view. So it leads to sloppy lines IMO if not managed.
Attached is a short video capture showing the workflow we typically go through just so we have a nice symmetric section line representations. That's a lot of steps we constantly do just to keep things tidy.
1 Comment
inv.ideareview
Status changed to: Archived
Thanks for sharing your Idea. The product team continually reviews this forum aiming to deliver in the most impactful way we can based on voting. We also regularly examine the list to make sure it reflects the most current Ideas. As part of this process we archive old Ideas that haven’t received broad support. This ensures there is room for new Ideas to be reviewed by the community and for the most relevant and meaningful ones to gain votes.
This Idea is archived because it's been on the board for over a year and hasn't received many votes. If you want to raise it again and try to gain more support across the community, you're welcome to do so. Leveraging images, animated gifs or sample mock-ups can help convey concepts and generate more votes from other users. If you have questions or see a connection between this Idea and others that should be accounted for, please let us know.
- INV.IdeaReview
