Create additional layers when exporting a Flat Pattern.
I would like to have the capability to create additional layers when I export a Flat Pattern.  That way I won't have to edit the DWG/DXF just to add in that information.
5 Comments
bverboort
Bryan,
Maybe I'm not understanding... but I think what you are asking for can be accomplished by using the DWG "Configuration" and/or "Post Process" capabilities (layers tab) in the "Flat Pattern Export Options" wizard.
Best,
Brian
BryanKelley
Hi Brian,
  Correct, but that has to be done everytime, I cannot set it within any type of template file since there is none within the workflow.  So the user must manually go through the process over an over.  If they have some downstream process that requires extra layers for their workflow, it may become tedious.  I placed this here to see if there was any interest from any end-users.
Bryan
rjay75
Hello Bryan.
Do you mean having the ability modify which layers are exported and what the layer names are? And the ability to save this information and select or have it preselected during the workflow of exporting?
I actually have a add-in going through the approval process now that adds this capability to the export process for flat patterns. Funny I actually considered adding the capability to associate a particular export configuration with a file so it could be preset in templates. May be worth doing now.
Here's a link to the command.
http://www.jaytekdev.com/flowtools/iv/2013/docs#exportflats
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
