Create a two-point-center rectangle
Solidworks 2012 (for sure) use the same method for this kind of rectangles.
I recommend use other way to avoid Construction lines.
What does it mean:
The idea is the same as for Horizontal and Vertical Constraints using points.
We chose Horizontal Constraint and select two points. It gives us two points lying on a horizontal non-existing line.
So my suggestion is to expand Perpendicular Constraint.
I wish to use Perpendicular Constraint for lines as well as for points.
How it works:
 We chose Perpendicular  Constraint
and select first point,
than vertex point,
then third point.
And we should get the following result:
The red point is a vertex of 90° angle (without any lines).
So we can get new solution for two-point- and three-point-center rectangles:
5 Comments
abramov
About Solidworks 2012:
They use diagonal lines.
Inventor can do 3 point angle dimensions without lines as is.
abramov
Yes it can. But You cannot do the same with rectangular constraint.
And Inventor cannot create three-point-center rectangle without diagonals.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
