Constraints for solid bodies in an IPT
I would like to to have a constraint feature for solid bodies in an IPT.
Sometimes you derive a body into a multibody part but its not in the desired position so then with constraints I can position it to where I want it and the position will update as I change the related geometry.
There is an app called bodybuilding but it doesn't run on Inventor 2022.
It is exactly what I would like to see as standard in Inventor
You can see it at the link below.
 https://www.youtube.com/embed/FVXrz6gKICg
