Constraint Value Dialog Box, back to bottom!
If I recall correctly, in previous versions (2016?) when you clicked on a constraint in the model tree, the value would appear in a dialog box at the very bottom of the model tree window.  In 2020 if you have your model tree narrow (to increase the size of your working space window), when you click on a constraint in the model tree, the value dialog box pops up directly BELOW the constraint and directly over top of the next item in the model tree.  When you're editing multiple items you have to pick the next constraint by picking around the value dialog box.
In order to get the value dialog box to appear to the right of the constraint, the model tree window needs to be much wider than the name of the longest constraint, and since that name is composed of the names of the two items in the constraint, you need the width of your model tree window about 25% or more of  your workspace.
This is a total waste of workspace!!!  If you're going to make the line of text for the constraint word-wrap as it does, have it bump the next item in the model tree down one line so you still see the whole thing, don't have it pop up on TOP of the next item.
Or better yet, move the value dialog box BACK TO THE BOTTOM where it was and where it worked well without obstructing anything else in the tree.   🤔
