Greetings,
Would it be possible to Manually add a tag to a part/subassembly in an assembly
With the goal that all new constraints made with/to that part/subassembly will start with that tag
Avoids the need to manually rename constraints for robust ilogic code when you start copying designs
As example 2 wheels are added in an assembly and a tag is added
FWL (Front Wheel Left)
FWR (Front Wheel Right)
Constraints being added always follow this theme FWL_01 / FWL_02
