It would be great if when working in a 2D sketch, either part or drawing, to auto (intelligently) swap the horizontal and vertical constraint button functions.
For example, when I start a sketch looking directly at the front view in a part everything works as intended.
Lines snap to horizontal with the horizontal constraint. Vertical lines snap to vertical with the vertical constraint.
If the view is now rotated 90 degrees, the lines snap to vertical with the horizontal constraint and horizontal with the vertical constraint.
Whilst this is correct function with respect to the planes / UCS etc, it is a pain when editing sketches as Inventor regularly rotates the view during edit to what it thinks is the orientation required (not always the case!)
