Apply Inventor IDW Sketches to specific Layers
When 'sketching' in an IDW in Inventor, you can set the sketch properties in the Sketch mode or afterwards in the sketch properties. However, you can't assign a sketch to a layer. I would like to be able to assign sketches to the layers defined in the styles and standards. Then when creating a sketch you can select the layer to apply the sketch to to automatically define its properties. If the layer settings are later changed then all of the sketches assigned to that layer will also nicely update as well. Currently all sketches are assigned to the 'sketch geometry' layer. So you can't set up one sketch as hidden lines, for ex., and another as visible lines and control them via layers, instead EACH sketch must be controlled and maintained individually. Thats just dumb...
7 Comments
inv.ideareview
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so.
inv.ideareview
Status changed to: Accepted
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
kent_wold
Sadly this is archived.. I have a need to do the same and have seen multiple workarounds on other sites and in the Forums... may not have gotten many votes but a quick search shows there is a need.
craig_embry
I would still like to see this.  Seems such an easy fix....
steforlts
I could use this function too
