Show only
Search instead for
This would be extremely useful for those who have a large amount of models with existing tolerances in feature dimensions, allowing for automatic generation of MBD data.
If you would like to promote all sketch dimensions to a 3d annotation then the below will achieve this, the annotations will appear with the text in the same position as the sketch dimension text.
Dim partDoc As Inventor.Document
partDoc = ThisApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition = partDoc.ComponentDefinition
Dim modeldims As ModelDimensions = oCompDef.ModelAnnotations.ModelDimensions
Dim oSelectSet As SelectSet
oSelectSet = partDoc.SelectSet
oSelectSet.Clear
'Wrap adding all annotations within a single 'UNDO'
oDoc = ThisDoc.Document
oUndoName = "iLogic Promote 3D Annotations"
Dim UNDO As Transaction
UNDO = ThisApplication.TransactionManager.StartTransaction(oDoc, oUndoName)
'Code inside UNDO here:
For Each oSketch In oCompDef.Sketches 'go through each sketch in the model
oSketch.Visible = True 'make the sketch visible
oSketch.DimensionsVisible = True 'make the dimensions visible
'select all the dimensions in the sketch
For Each oDim In oSketch.DimensionConstraints
oSelectSet.Select(oDim)
Next
Call ThisApplication.CommandManager.ControlDefinitions("3daPromoteDimensionCmd").Execute 'promote the dimensions to 3d annotations
'if you dont see annotations try this line below
'Call ThisApplication.CommandManager.ControlDefinitions("PartVisibilityCtxCmd").Execute
oSketch.Visible = False 'hide the sketch again
oSketch.DimensionsVisible = False
Next
UNDO.End
