Could the software please please be updated so that text can be imported via an excel spreadsheet the same way numbers can be imported?
Currently the only way is to use iLogic and specify an individual cell. This is problematic and time consuming, and I'm confused why text can't be imported using the same way numbers are. Surely this doesn't require a complicated modification to the software?
As far as low hanging fruit, surely this could be made a priority??
It will benefit sooo many people, being able to control a table driven model's part numbers, colours, descriptions etc etc without having to fiddle around with additional (and totally unnecessary) text import iLogic rules, having to manually create each user parameter in each model/file and having to specify individual cell locations which if you accidentally move, break...
Thanks!!!!
