Add 'Tube lasercut' to 'split' command
It would be awsome to have a Laser cut option in the split tool.
In the '3D Model' tab, section 'Modify', feature 'Split' there is a command called 'Trim Solid'. I would love for this to have an extra option to go along with it. This should be the option to "mark" the split as an Laser Cut feature for fixed head laser cutters. So the kept body will be left with the properly modeled edge. I know there are state of the art tube lasers that are able to move there head to be able to cut almost anything, but my experience is that there are still many machines that can't. To make a correct model now takes a lot of splitting and Thicken/Offset feature to make a singel cut.
Having an option to mark "Laser cut" to the 'Trim Solid' command, would shorten the feature tree, and most important save me a lot of time.
3 Comments
DRoam
@Anonymous, can you post a sample picture of what the Split command does now versus what you would like it to do?
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
