Add radius to sweep command to easily create pipes, railings etc.
I would like to see a 'radius' option added to the sweep command to simplfy the creation of pipes.
I have to model a lot of railings, arches etc created out of metal tubes and pipes. At the moment I have to create the 3D path, create a workplane at one end and then sketch a circle on the workplane, then sweep that along the 3D path. It would be much quicker to open the Sweep command, select a 3D path and specify a radius and have Inventor automatically create a tube following the 3D path.
I know Frame Generator can do this- but that creates seperate parts, and is too complex for what I am trying to do.
1 Comment
inv.ideareview
Status changed to: Archived
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes.
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know.
- Inventor product team (Inv.idea review)
