Add Override Color to SketchPoint Object
Please add Override color to SketchPoint Object, similar to the SketchLine object.
Reasoning:
The selectset and highlight set are unreliable and sometimes we need to change the color to use the pick command and a windows form. And changing the color of the object is the only reliable way to go through the selection process.
Sketchline Override color: https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=SketchLine_OverrideColor
Thank you
Idee einsenden
