When using the "Ground and Root Components" command in an assembly, the added dialog box that pops up since the 2018.2 update adds clicks to the workflow if you never change the settings. Would love to see a checkbox to set default settings and "Don't show this again" to suppress the dialog box. (Of course, also add this to the Prompts tab in the application options so you can change this behavior down the road for when you change your mind.)
Workflow would then be to simply select component(s) and right-click to pick "OK" or hit ENTER to finish the command. Could also employ the mini-toolbars to add an "Apply" option.
