This is the only cad program I have used that defaults to radians when importing files. This is also the only cad program that requires the units be changed on every single step file instead of allowing a one and done setting that applies to everything always. Not everyone has access to the source code to be able to permanently fix the issue (which is something no one should have to do in the first place), so adding this option seems like a no brainer. I guess it does take at least one brain cell though, because if it didn't inventor would have fixed it.
