Add a Radial Pattern Feature
A radiated pattern would be something like a shower head pattern. Where the pattern "radiates" from the center point with an initial circular pattern and in incremental steps in radius the circular patterns that follow increase their pattern number by a given multiple. So for example, the first circular pattern will start off with 6 points at a radius of 10mm, then the second will be a circular pattern of 12 points at a radius 20mm, the third a circular pattern of 18 points at a radius of 30mm, etc. Although this can be done with individual circular patterns, it becomes frustrating when having to do this 30 (plus) times.
1 Comment
jingyi.liu
Thanks for your feedback, please refer to below similar ideas and cast your votes there.
https://forums.autodesk.com/t5/inventor-ideas/add-a-radial-pattern-feature/idi-p/8004940
https://forums.autodesk.com/t5/inventor-ideas/table-driven-patterns/idi-p/5539383
