To give a realistic view to an assembly it would be good to see if a mechanical assembly can actualy work within the degrees of freedom that influence it.
You can for example make a spring adaptive give two items limited constrains, but why is it not possible to combine and to make it work like it would in reality.
I know adaptivity has it limits and might disappear in time, but there should be a way to make a simple example as in the screencast below to work within the limitations of the constraints. There mostly isn't a need to create a complete presentation of simple assembly but might be usefull to check them.
