Ability to have a flexible sub assembly and make it part of a contact set
It would be really useful in Inventor if you could have a flexible sub assembly, which could then be part of a contact set within a higher level assembly (GA).
At the moment, you can make a sub assembly flexible or part of a contact set, but not both at the same time.
The workaround is you have to re-structure your assembly, promoting the parts in the sub assembly to the top level GA, where you then don't need to make them flexible, so they can be part of a contact set. The only problem is now you have blown away your assembly structuring for BOM/Parts List purposes.
4 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
cvbt-thailand
Can we unarchive this please. I would like to vote for it. I have found a need for it in my assembly.
SER4
Phantom voted.
This has been a request for over a decade:
https://forums.autodesk.com/t5/inventor-forum/flexible-and-contact-set/td-p/2449082
