Ability to edit dimension options on multiple drawing diameters/radii simultaneously
This would greatly shorten the right-click selection and editing time for drawings where many diameter/radius dimensions needed changed to arrows inside and/or dual arrows to single arrows or vice versa. Please add the ability for the Engineer to select multiple diameter/radius dimensions in the drawing, and then right-click select "Options", then either "Arrowheads Inside", "Single Dimension Line", or "Leader From Center" options, simultaneously changing all selected dimensions at once. Any time savings is a good time savings.
1 Comment
swalton
Do you use the Copy Properties tool?  It might be a useful workaround.
See: https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=GUID-03BB999D-33F0-432F-B969-ABFEDF5B470A
