Ability to create sheet metal contour roll feature through API
https://forums.autodesk.com/t5/inventor-ideas/ability-to-create-sheet-metal-contour-roll-feature-thr...
Yes, creating a flat pattern for the reinforcement pad would be very helpful and save time for Codeware's Compress 3D to production layout process. The alternative is to make a copy of the vessel. Remove the pad, match the shell size and thickness to the pad. Export, etc.
