Hello, here are a few ideas to improve 2D sketch design:
1: the possibility of offsetting a line or a series of lines on both sides with one function.
2: the ability to close a contour when offset (e.g.: I draw a line that I offset to the right, two segments are created between the two to form a rectangle)
3: when creating a fillet with the fillet (or chamfer) function, the two intersecting lines remain in "memory", so that if I delete the fillet, the two lines come back into contact (today, the two points must be recontracted together)
4: the ability to create a line from its midpoint
5: the ability to make slots equal without having to select an arc of each and then the line of each. No matter whether I select a line or an arc, the software will detect that it's a slot
6: the ability to add or delete geometric elements in a repeat that were not there when it was created
7: the ability to select a loop of sketch geometry (e.g. a rectangle in a single click)
