Inventor General Discussion
Advocate hlo
13 Solutions
Post 1 of 5
Stress analysis - deflection of a steel block
430 Views, 4 Replies
11-19-2012 03:21 AM
HI
Is it possible to calculate the deflection a steel block will get, just form it one weight
Just use standard steel material, it is only supported at the end.
Regards
Henrik
Yes, it is possible. I assume you want to place the Weight positioned along the bar at a set distance.
You can do this by splitting the face with either a circle or rectangle and placing your force there.
I have attached an example. Hopefully I have understood your question.
Jon.
The Gravity Vector is just that, the direction/vector that gravity will affect the model in question. It doesn't matter which object/edge you select. If an edge is not in the correct direction, you can expand the box and enter a vector using the XZY boxes.
You need to create a sketch on the desired surface and then create a closed loop then exit the sketch. Select the Split Tool command, then the sketch (closed profile) and finally the surface in question.
If you wish to apply a load to a given spot/area on a surface, you would be required to use the Split Surface to create a separate surface in which to apply either the force/load or support constrain. Otherwise Inventor will apply the load/constrain to the whole surface face.
Autodesk Support
30 Kudos
107 Solutions
Post 2 of 5
Re: Stress analysis - deflection of a steel block
11-23-2012 07:11 AM in reply to: hlo
Jon.
Jon Dean
AUTODESK EXPERT ELITE
981 Kudos
419 Solutions
Post 3 of 5
11-23-2012 11:58 AM in reply to: jon.dean
Remember to add the directionof gravity to your analysis (if applicable).
IV2016 R2 PDSU / Sim Mech 2016 /
Win7-64 iCore7 3930k 32Gb ) Nvidia GTX-980 Classified - 355.60
SpacePilot Pro 10.2.2
Mac Pro 32Gb,Xeon 3.7GHz, dual AMD 700, Boot Camp 6.0, Win10, SpacePilot Pro 10.2.2
Delta Tau Chi ΔΤΧ
Advocate hlo
13 Solutions
Post 4 of 5
11-25-2012 12:06 AM in reply to: blair
HI
Hi
Thank for reply, i do understand the estimated setup and way to get a bending result
The gravity vector where shout it be placed in this example
Another question regarding the use of split tool, what dose I do to the surface, is it only
marking a round spot and not removing  anything.
Regards
Henrik
Highlighted
981 Kudos
419 Solutions
Post 5 of 5
11-25-2012 10:47 AM in reply to: hlo
Delta Tau Chi ΔΤΧ
Community Alert
The Autodesk Community Forums, Blogs, and Idea Boards will be in read only mode starting on 2/12 at 9PM PST through 12PM PST on 2/13. Please see the following for more information: Site Maintenance Notification
Community Alert | The Autodesk Community Forums, Blogs, and Idea Boards will be in read only mode starting on 2/12 at 9PM PST through 12PM PST on 2/13. Please see the following for more information: Site Maintenance Notification
