Inventor General Discussion
1 Solution
Post 1 of 3
Sheet metal unfolding
515 Views, 2 Replies
02-02-2013 12:13 PM
For some reason I cannot unfold sheet metal product on attached file. Where have I made a mistake? I used extruding, also sheet metal thickness from rule has been set to 2mm. Rest are default values.
BR,
Marko
Your Sketch1 is not constrained and dimensioned.  If you edit the sketch and look in the lower right corner, you will see "48 dimensions needed".  A properly constrained sketch will report "Fully Constrained".  So, you will need to get some training (see Help for tutorials, search here for JDMather's basic skills documents).
Modeling tips: as JDMather often writes to new Inventor users "You're doing way too much work.  Get lazy."  I would use the Contour Flange tool to avoid so much sketching and constraining, and I would model half of this, then mirror.  See the attached for one way to accomplish this.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Highlighted
399 Kudos
268 Solutions
Post 2 of 3
Re: Sheet metal unfolding
02-02-2013 05:37 PM in reply to: Pentamet
Sam B
1 Solution
Post 3 of 3
02-03-2013 02:31 AM in reply to: sbixler
Thank You Sam!
