Exporting this drawing from IDW to DWG in 2013 took about 2 minutes.
Same model migrated to 2014.
"Save copy as AutoCAD DWG" takes about 50 minutes.
The attached screenshot was taken after about 26 minutes running, The progress meter just gone past half way.
Is this normal or just a glitch of migrating ?
Julian
Inventor Professional 2014
Windows 7 -64 Ultimate
12 GB RAM
Solved by blair. Go to Solution.
Time would depend on system and network speed and complexity of the model.
I normally migrate all IPT's first, then the IAM's second and finally IDW's last. If you use a lot of IPN's, then migrate them after the IAM's and before the IDW's.
